Need help now
Ronneysmith2022
Can in my acc
7 REPLIES 7
iliketotalk
@Ronneysmith2022 you will need to open a ticket through Simon to speak to a customer service agent they will help you  Click here
@Ronneysmith2022 wrote:
 I forgot my email and my password
@Ronneysmith2022   You can follow what I suggested above to reset the login credentials
Good Luck
@Ronneysmith2022
Wait 15 minutes then clear cache, cookie and go incognito. Login and click Forgot Password and answer your security question.
DDM69
I would recommend you write it down somewhere for future reference.
@Ronneysmith2022   You meant you cannot login to your account?
if that is the case, if it said locked, wait an hour and try again
If still fail, try the Forgot passoword link ( https://selfserve.publicmobile.ca/forgot-password/ )
If unable to self reset the password that way, try to open ticket with PM support:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Ronneysmith2022
iliketotalk
@Ronneysmith2022 @Hi can you be a little more specific?
