Need a PUK Code - Moderator Please Help
mantoniopereira
iliketotalk
@mantoniopereira Hello before you go contacting the moderator what exactly is the message you were getting on your phone did you just activate your account does it need to be unlocked What kind of phone is it
Triguy
Here is a detailed explanation by one of the Oracle's Luddite. "SIM network PIN blocked. Enter SIM network PUK."  is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.   "SIM network unlock PIN"  is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.   “PIN unlock key (PUK)”  is a SIM-specific code used to prevent unauthorised use of a SIM card.  The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.  If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it. Once the PUK is recovered and validated, you will be asked to choose a new PIN. Only Public Mobile's moderators can give you this type of code, which the device manufacturer cannot. Public Mobile's moderators can be contacted at the following address:   https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437  Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
gblackma
@mantoniopereira  contact the moderators and ask them for it. Click on the green questionmark in the white circle at the bottom right of your screen.  This connects to the autobot Simon.  Type moderator and follow the prompts to get to one (CLICK on "Account specific question" and  "No I want a human" and "Submit a ticket Click me!")
Once connected, you will be asked to log in again with your community user name and password.  Please do, this allows you to continue and send your message.
Check your private message sent box (click on the envelope top right of your screen) to make sure the message was sent. Also keep an eye on the envelope, the mods answer will show up there.
You can also enable email notification to receive a private message notification sent to your email.
Go into your community account > my settings > PREFERENCES > Private Messenger > enable "Receive email notifications for new private messages" > Save
Stay safe.
JoyLuck
Please use the chatbot  SIMon to help you solve your issue. If SIMon cannot solve  your issue then you have the option to contact a moderator.
Step 1: Choose the ? button at the right bottom corner of this page or choose “Get Help” at the top of the page and then choose the “Chat with SIMon” button.
Step 2: Tell SIMon what the issue is and see if he can find a solution for you.
Step 2: If Simon cannot find a solution then type in “moderator” to connect to a Public Mobile customer service representative.
Step 3: Simon will present you with two choices. Choose “Account-specific question”
Step 4: Then choose “No, I want a human”
Step 5: Create your ticket
Check the sent folder to make sure your ticket was sent (envelope icon, top right) and the inbox for a reply from the moderators.
“To ensure the safety of our team members during the COVID-19 pandemic, our Moderator team is working at reduced levels. During this time, you may experience longer than normal wait times when contacting our Moderator team for help.”
Moderators are available:
Monday to Friday from 8 AM to midnight Eastern time.
Saturday and Sunday from 8 AM to 10 PM Eastern time
