Need a APP
Souky123
When will there be a PM app?
7 REPLIES 7
srlawren
@Souky123 depending what you're looking for, there are some possible solutions.
If you're looking for data tracking, if you have an Android phone I highly recommend you check out Data Witness PM, provided for free by community member @IWIK.  You can see my hands-on with it here https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/IWIK-s-quot-Data-Witness-quot-for-And..., and if you're interested, download the free-to-PM-subscribers version here: https://play.google.com/store/apps/details?id=com.iwik.datawitnesspm.  Another option is a 3rd party app called My Data Manager, however it has some potential privacy issues which make it difficult for me to recommend.  If you're on iPhone, My Data Manager is probably your best bet.
If you're looking for mobile app self-serve and/or the community and you're on Android, check out how to appify the sites using Hermit Lite:  https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Very-Partial-workaround-for-lack-of-P...
Souky123
Awesome thank you would be nice
@mimmo wrote:
@NDesai wrote:
Yup, it won't happen. Koodo had an app and they got rid of it for a reason.
But koodo does have a much friendlier/ mobile friendly portal....
That's for postpaid. For prepaid, it's exactly the same 🙂
mimmo
mimmo
 NO app Will be made. If you need to track data use my data manager or data witness pm
Else just bookmark the forum and selfserve.
NDesai
MoreYummy
Its probably wont happen.   There is a simple app made by our member in the forum.  Not sure if that still work now.
