Need QR code for esim
hbaiyat
Hi, can I please get QR code for esim to scan please. Thank you.
2 REPLIES 2
fixin1
@hbaiyat - In your welcome email it should look like this:
Welcome to Public Mobile  copy-images-1.pngWelcome to Public Mobile  copy-images-2.pngWelcome to Public Mobile  copy-images-3.png
The eSIM may also be in your Cellular settings, so make sure it is enabled and set as primary.
If the QR code does not work, contact CS_Agent:
Submit a ticket via Chatbot:
⬇️  Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
@hbaiyat you sure the esim has not installed yet?  Check your Sim Manager or Settings  > Cellulars
if really not there, check Welcome email and there should be the QR code there
if you cannot find the the QR code still, please message support agent for help, they can resend you the QR code
