Need PUK
06-06-2024
11:43 PM
06-06-2024
11:47 PM
computergeek541
06-06-2024 11:47 PM
Is this the PUK of your SIM card or is a SIM Network Unlock PUK. A SIM network Unlock PUK would mean that your phone is locked to a different carrier and you would need help from that carrier. For your Public Mobile SIM card's PUK, you'll need to open a ticket using the chatbot. https://widget.telus.tiia.ai/publicmobile/publicmobile.html
06-06-2024 11:46 PM
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
call Samsung 1-800-726-7864 for a master unlock code.
The only info you will need to provide is the IMEI and where the phone was purchased
open message support here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
or use this direct link to open Chatbot ticket: https://urlshortner.tiia.ai/Oyn1L6
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened. CS Agent will reply to you there.
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier help unlocking it.
(Sorry, for this particular issue, PM support would not be able to help)
