Need PUK Number
MistyJade
Need PUK number
@MistyJade   have you been using a SIM PIN for protection?
if the phone was used on PM network (or Telus network before), then i will message PM support for the sim card PUK:
 https://urlshortner.tiia.ai/Oyn1L6
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
@MistyJade wrote:
Its a samsung and says SIM card locked. Enter PUK.
This means that you will need to ask a Public Mobile CSA for this code. This isn't something that Samsung would be abe able to assist with.
MistyJade
@MistyJade   what was the exact error message?
there are different PUK.  could be a SIM card PUK if you have been using SIM PIN.  Or could be a device PUK if the phone has never been used on PM network.
Depends on the error, you will need to ask the PUK from difference sources
If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK." ,
call  Samsung 1-800-726-7864, The only info you will need to provide for a master unlock was the IMEI and where the phone was purchased
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM cannot be accessed" or on an iPhone's status bar showing  "Locked SIM"
open a ticket with PM Support using this direct link:  https://urlshortner.tiia.ai/Oyn1L6
If the message is "SIM network unlock PIN" or "SIM ME lock code NP"  or  on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier unlock code. (PM would not be able to help with this)
@MistyJade wrote:
Need PUK number
Please note that the member name that you tagged (Moderator) isn't a moderator of any kind.  For your SIM card's PUK, you will you need to submit a ticket using the chatbot.  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
