Name display
Tharshi06
Hi,
my daughter signed up with public mobile and she is using one of the old number. when she call her name display with old user's name.
could you please help us to fix this issue.
Thanks,
TT
cellphoneuser1
@Tharshi06 wrote:
Hi,
Thanks,
TT
Only Rogers and landlines send name display when making a call.  Was the number registered with an internet database with a name?
As @Purplepan says, look in her contact s and see it the former owners name appears. Change the contact info to her.
Tharshi06
Her name display as old user's name (who ever owned this number before). Example my daughter's name is Linda, but name display as Heshini which is the old user
Purplepan
Hi there,
Incoming calls from Public Mobile customers will only display the phone number.
Do you have your daughter as a contact on your phone? If you've set up a contact for her, the display name will be whatever you chose for her locally on your phone. So for example, if you added her phone number as a contact and labeled her as "Daughter", it'll always show as "Daughter" for your phone only as long as her number remains the same. If she calls a random phone, it should only display her phone number.
Hope this helps.
steff12321
You'll have to message the moderators for this @CS_Agent
