09-08-2020 01:56 PM - edited 01-05-2022 03:49 PM
09-08-2020 03:32 PM
@Coco51 Try switching your sim into another phone to see if its the phone or the sim. If its the phone try a network reset and restart your phone if it doesn't automatically do so.
If its the sim and you tried the other suggestions above. Log into your self service account and choose the change sim option and compare the last 4 digits to the sim card in your phone. The Sims should match. Let us know if they do or don't. Thanks. Stay safe.
09-08-2020 03:27 PM
09-08-2020 02:08 PM
Login to self-service account and make sure that your status is Active. Then, restart your phone and when trying to call someone, add +1 in front of the area code of the number you are calling. If same mistake happens again, then wait for assistance from moderators.
Good Luck
09-08-2020 02:07 PM - edited 09-08-2020 02:08 PM
@Coco51 wrote:My service is not working
Are all the features not working ? Is text and data still working ? Perhaps you've run outta calling minute on the $15 plan ?
Did you enable Autopay when you signed up ?
Call 611 for plan status.
09-08-2020 02:06 PM
@Coco51 Check your self-service. Is the status Active? Maybe you need to do a manual payment and reactivate your service.
09-08-2020 02:04 PM
When is your renewal date?
If it is this morning, check your account status on your self-serve account.
If it is expired or suspended, pay the fee and click on the reactivate my current plan link to get your phone working ASAP.
09-08-2020 01:58 PM - edited 09-08-2020 02:03 PM
@Coco51 Did you just sign up and are in the process of porting? That can take 2 or 3 hours to complete. You should also try rebooting your phone.
Edit: I see you signed up almost a month ago, so is this an interruption in services that just happened? Try the reboot first to see if that will help.
