My refer a friend code is NOT working!
buang99
Is there any reason my refer a friend stopped working? 😕
1 ACCEPTED SOLUTION
Accepted Solutions
z10user4
What do you mean "stopped working"?
If your referred friend suspends or ports out then you would lose that referral.
Is it that you're not getting the $1 anymore? Can you prove that the friend is still with Public Mobile?
There was a system purge a while ago and maybe it sweeps through periodically to remove invalid referrals. Maybe it's not perfect.
LovesToPM
Hi @buang99
Why do you think it stopped working?
Is your current plan still active?
z10user4
Jb456
If it's not what others have already said. Do you possibly mean your referral code has either an O (Alphabet) or 0 (zero) and that is what is not working? Because it's entered wrong🤔
ShawnC13
Are you able to go into more detail on this and explain what has happened?  Did you lose a referral or did someone try and join with your code and it didn't work?
NDesai
@buang99 What do you see in the "Enter Referral Code" field if you visit the link: https://activate.publicmobile.ca/?raf=XXXXXX <= your referral code?
_________________________________________________________________________________________________
If you need to contact PM Customer Support Agent, create a Ticket.
New Here? - Check out Knowledge Base Articles to learn more about Public Mobile.
devraj5698
buang99 Try to see if the other party entered the correct code, otherwise best would be to talk to a moderator to resolve the issue.
