My phone was stolen
03-04-2019 03:35 PM - edited 01-05-2022 03:35 AM
03-05-2019 02:50 PM
That's why I won't get an expensive phone. Could you imagine having the lastest $1500 Samsung10+, and having it stolen?
03-05-2019 11:01 AM - edited 03-05-2019 11:05 AM
If it is an Android phone and you use Google Services (ie Playstore, Gmail etc), just go to https://www.google.com/android/find
Or just type 'find my phone' into google if you're logged in to google services on the pc.
It will at least tell you the last known location before the theif disabled communications or you disabled the sim (or current position if the theif is dumb enough to leave wifi turned on).
03-04-2019 03:56 PM - edited 03-04-2019 03:57 PM
@Leonard wrote:My phone has been stolen, I would like to know what i can do?
What kind of phone is it? If it's an iPhone (and assuming you've set up AppleID and enabled Find my iPhone), before suspending the account as recommended by others here, I would also recommend logging into your iCloud account and then remotely disabling the iPhone and then trying to locate it (will work as long as the thief hasn't disabled comms, and also assuming you have a data plan). If you've set up an AppleID on it and added adequate security (passcode/TouchID to unlock), then the phone is pretty much useless to anyone who steals it.
If it's not an iPhone, then this post is irrelevant!
03-04-2019 03:48 PM
You can suspend your service by logging into your Self Serve account > Plan and Add-ons > Lost/Stolen Phone > Suspend Service.
03-04-2019 03:40 PM
Sorry for you @Leonard
@You can go in your self serve account and put your phone on lost stolen.. in plan/add-ons... when you will buy a new one you can click on found your phone and after you can change the number of your SIM card in same place.
03-04-2019 03:40 PM - edited 03-04-2019 03:40 PM
You will need to log in to your self serve and then go and report your phone lost/stolen through the link. This will deactivate your SIM.
ETA Ah beat again crazy slow computer
03-04-2019 03:38 PM - edited 03-04-2019 03:41 PM
