10-24-2023 06:14 PM
Today was using my cell, hung up from one call, tried to make another, 6 hours later I'm here still with zero service, I'm disgusted
11-24-2023 07:36 PM
Hi, I tried the sim in a new Iphone 14 as well and only showed SOS. No service.
10-25-2023 12:58 AM
Are you on the $15 plan? If you are then you may have used up your 100 minutes of outgoing calls.
10-24-2023 11:05 PM
@Brodies1000 wrote:Tried both of those
No luck
@Brodies1000 if your phone is not blacklisted, and you tried your sim card into another phone, then log into My Account to check the status of your account/plan.
Or, when you call 611 (or # 1-855-478-2542 or # 1-855-4PUBLIC from another device) what does it tell you?
If your account is in Active status, try cleaning the contact points of the sim card and reinsert it into your phone, see if that helps.
10-24-2023 10:09 PM
Tried both of those
No luck
10-24-2023 08:31 PM
maybe your account didn't renew correctly. is today your renewal date?
10-24-2023 06:22 PM
Hi @Brodies1000
It's rare a SIM card dies however it does happen depending on it's age. The SIM card could have been dislodged inside. Try taking the SIM card out, re holster it, insert and reboot. If that doesn't bring you back, then if you have access to another phone, try it in there. If it doesn't work, could be a few options. The SIM has crapped out. Or your account could be in bad standings. Let us know.....
10-24-2023 06:17 PM
Try your sim in another phone. Also, have a look at devicecheck.ca to rule that out.
