12-02-2022 02:07 PM
Hi I don’t know my account email address how can I change that
12-02-2022 02:09 PM
Contact agent to help you out.
To Contact CSA-agent; there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
Watch for envelope in top right corner of Community page. It will show Number of unread emails.
12-02-2022 02:09 PM
@Gurjotchani23 you can try to use Reset Password link and enter all the possible email address used , see which one got the reply from PM
but an easier way, and you can also ask PM to change the email for you, open ticket with PM Support
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
