09-02-2015 04:58 PM - edited 01-04-2022 12:43 PM
My Motor G, which is approximately one year old, has stopped working. It won't turn on or off and is stuck on the Globe with the Motor G message beneath it. Help. I need my pictures and videos and my phone has a password lock. What should I do?
09-04-2015 03:59 PM
If so, I'd suggest you try there.
Other than that, My only suggestion: Purchase a new Handset
09-04-2015 03:58 PM
Do you know any 3rd party cell repair center near you?
09-04-2015 03:55 PM
No. He was not able to do so.
09-04-2015 03:55 PM
If not, the tech should had done that to see if that resolves your issues
09-04-2015 03:54 PM
There maybe an internal issue with the phone
Has the Koodo Tech been able to at least, remove the screw and battery and then reinserting it back in?
09-04-2015 03:51 PM - edited 09-04-2015 03:53 PM
Thanks for all the suggestions. A little more info may help. I drained the battery and then recharged it, and then turned it on. Went to the Koodoo store and the tech there tried to do a battery reboot and as there is a password, it doesn't seem to be possible. Also, tried to turn off the phone, it goes off, and them comes back on withing a second. It will not properly turn off. The tech said the password needs to be removed before a reboot could be done... Any suggestion would be appreciated from this totally non-techie.
09-02-2015 05:53 PM
tsk, so intuitive, lol
09-02-2015 05:51 PM
@Martin Dang, just when I was getting the hang of it!
09-02-2015 05:49 PM
ONLY by 3 Generations LOL
09-02-2015 05:48 PM
09-02-2015 05:48 PM
I don't know.
Ask the Android that. I'm rather curious myself
09-02-2015 05:46 PM
Wonder what @thevinnew thinks of all this chatter.
BTW Android gurus if it is a battery issue, would using the phone while on the charger demonstrate the problem?
09-02-2015 05:46 PM
09-02-2015 05:39 PM
@Martin, If @thevinnew doesn't have the correct Screw Driver, How much for that, and where can he purchase it from?
09-02-2015 05:37 PM
@Martin Whoops, forgot that possibility. Where is that colander when I need it, anyway?
09-02-2015 05:35 PM
09-02-2015 05:34 PM - edited 09-02-2015 05:35 PM
09-02-2015 05:33 PM
If you need a New Handset, Here's some places that you can look at:
Telus (Online)
Apple
Blackberry (BBM)
One + One
Alcatel
Costco
Google Nexus
Microsoft Store
09-02-2015 05:32 PM
@thevinnew, If you don't have the certain Screw Driver head that fits, then perhaps you should consider taking it to a Repair Center
09-02-2015 05:17 PM
IF you have the Special Screw Driver, and Know what you're doing, YOU CAN
NOT SURE IF, and ONLY IF, WARRANTY IS STILL IN EFFECT, and by removing Battery that way, since Battery requires a Special Screw Driver, Would it VOID Warranty
09-02-2015 05:12 PM
That makes it more difficult for sure. Need a repair shop then?
09-02-2015 05:10 PM
Plus, a special Screw Driver maybe needed to remove the Li-on Battery
09-02-2015 05:09 PM
@Luddite, The Moto G Battery is NOT as simple to remove
09-02-2015 05:09 PM
Try taking the battery out for a few minutes then try to restart your phone. If it comes back up, it would be good to make a back up of everything immediately, and also charge it if low.
09-02-2015 05:08 PM
How much battery is left in the Moto G?
09-02-2015 05:07 PM
If nothing happens, Either the Internal Battery is History, or some other internal part in the Moto G is not functioning
09-02-2015 05:06 PM
Try pressing on the power button for a min, see if that may help
