My Account option does not show
PreachJohn1A
On my New Account and 2nd phone line Account the My Account option does not show/load. No access to it. I want to change password/email and such.
2 REPLIES 2
PreachJohn1A
I figured it out. I clicked Community. I had to click Register for the New Acc't. When I did there was no Registration req'd. It got me in for what I was looking for. I just had to click on Settings. That worked.
JohnB
HALIMACS
@PreachJohn1A
did you set up an Eversafe  account for the second account?
each account requires a separate email address, make sure you are not using saved credentials to login.
if you require customer support assistance, here’s how to reach them:
To contact a Customer Support Agent, send a private message to the Customer Support Agents by clicking here
You’ll need to be logged into your Community account for the link to work.
