Multiple lines
ljdemont
Can I have more than one line on my account?
Derek1212
You can only have 1 line per account with one email address. If you need more lines use another email address for a new account. Don't forget to use the refer a friend code you will get 1$ off a month on your first account and also receive 10$ off your first month on the new account. You can use the same credit card and get the 2$ auto pay savings on both accounts
ljdemont
Thank you!
dabr
Each number/line requires it's own account and different email.  You may use the same CC for billing purposes though.
GinYVR
@ljdemontNo, one line per email.
