Multiple lines
gauthier_eli
Hi all,
can I get multiple lines with PM under 1 name?  Adding the hubby, and the teens... or I have to have them all separated?
Thanks 🙂
gauthier_eli
Awesome, thank you!
wetcoaster
One number per account.
Each account needs a separate e-mail address but you can use aliases if you use Gmail.
ShawnC13
@gauthier_eli wrote:
Hi all,
Thanks 🙂
@gauthier_eli, each phone number is its own account and would require a seperate email as well. (can use gmail alias's) You can pay for multiple lines with the same credit card though.  It used to be two lines for one card but I think people have found you can have more than that now.
