09-16-2020 08:45 PM - edited 01-05-2022 03:55 PM
Moving out of province, do I need to get a new sim card, or just change numbers? I'm not sure how this works.
Thanks 😊
Service
09-17-2020 04:19 AM
Thank you, much appreciate your help 😊
09-17-2020 04:18 AM
Perfect, thank you so much 😊
09-17-2020 01:21 AM - edited 09-17-2020 01:22 AM
@Dburg You current sim will work without any issues. You can change to a local number if you wish using the change number option online via your selfserve account. Also don't forget to change your cc address details once you have completed your move of you have Auto-Pay enabled.
09-17-2020 12:12 AM
It is up to you whether you change your number or not.
If you move to Alberta and change to Alberta number, you will be saying sales tax. You pay only GST.
Login to your self-serve account.
Click on the Change Number link in the My Profile box to change your phone number.
You are allowed to change your phone number every 30 days (may be monthly ??)
![](/skins/images/1E106844C188A5F605CF250A6344FF3B/responsive_peak/images/icon_anonymous_profile.png)
09-16-2020 08:49 PM
@Dburg wrote:Moving out of province, do I need to get a new sim card, or just change numbers? I'm not sure how this works.
Thanks 😊
This is a nation-wide service. It's your choice to change your number. It is always the case that anything long distance is on the caller, not you. So calling you depends on their calling plan.
If you have a current Canada-wide plan then you have nothing to worry about. If you have an older provincial plan then you can call in the province you're physically in.
09-16-2020 08:48 PM - edited 09-17-2020 02:59 AM
Thanks 😊
@Dburg You don't have to change either SIM or number. The only thing your moving affects is when anyone calls you from the province you're moving to and if they don't have long distance calling on their end, then they may have to pay long distance fees.
09-16-2020 08:47 PM - edited 09-16-2020 08:48 PM
@Dburg You can simply change your number in your self serve account. It can be done once every 30 days. No need to get a new sim.
![](/skins/images/813D49D689E0D681E39391EAB60FD666/responsive_peak/images/icon_anonymous_message.png)
