Monthly limits
Lawgirlnic
What happens when you reach your data limit? Are there overage charges?
joendonna
HI Lawgirlnic
No, there are no overage charges...  That is the wonderful nature of prepaid.
By default, your data wll stop working...
BUT ... If you buy a Data add-on now, it will be available to be automatically used after you hit your limit.  And the other beauty.....  it never expires .. so it just sits there .. waiting for the day that you go over.
Another wonderful aspect...  If you only go over your monthly limit by 20MB...  it only uses 20MB from the data add-on your bought.
Hope that helps.
