05-03-2025 10:18 PM
05-04-2025 11:39 AM
I was able to get agent to refund amount. Thanks for help . Awhile ago they didn’t want to do it but said they would now .
05-03-2025 11:02 PM
Appreciate it thanks
05-03-2025 10:58 PM - edited 05-03-2025 10:59 PM
@Leroy97 wrote:How do I get my money back . Kinda silly
@Leroy97 it is not silly, it just limitation. There are some numbers you cannot move to Telus, but also other numbers cannot be moved to Rogers or so
For refund, you need to ask PM for that. Since the number cannot be ported , they will usually agree to proceed refund. Please check with PM directly.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
05-03-2025 10:57 PM
05-03-2025 10:56 PM
yes, turn out 807-271 cannot be transferred to any Telus owned providers. You will have to stick with Rogers or Bell or Shaw
05-03-2025 10:53 PM
Yes it is but it’s not possible to transfer apparently . 807-271
05-03-2025 10:20 PM
is the number still active with another provider?
what is the area code and the next 3 digits?
05-03-2025 10:20 PM
hi @Leroy97
many numbers can be ported here, check with PM support agent and see if the number can be ported first. If not, then ask for refund
you can submit ticket by direct message:
05-03-2025 10:20 PM - edited 05-03-2025 10:20 PM
Public Mobile is reluctant to grant refunds, as a rule. You can use this link to message Customer Support to see what they can do.
