01-30-2020 02:39 PM - edited 01-05-2022 10:28 AM
Hi,
In the credit card information input there is an option to select "Moldova Monaco" as a country. Those are two separate countries. I have a credit card with Moldova address and am unable to use it as a result. It also requires me to input a province, Moldova doesn't have provinces.
Regards,
Lucian
Payment
01-30-2020 03:17 PM
Not sure yet, but if you like you can set the plan up by buying a public mobile voucher. How it works is
1) Go to a place that sells PM recharge or voucher
2) During the plan activation screen , select voucher instead of credit card
3) Then you will be able to activate the plan
Vocuhers can range from $15 to $50 Plus tax depending on the plan you are trying to activate
01-30-2020 03:12 PM
Just wanted to use a different card. Thanks.
Do you know when international cards will be able to be used?
01-30-2020 02:43 PM
As of now, PM does not support international credit cards but they are working on it.
Are you signing up for a new number or are you trying port a number ?
Thank you
01-30-2020 02:42 PM
PUBLIC Mobile accepts credit cards (Visa, MasterCard, American Express) and Visa Debit cards that have been issued by Canadian or American financial institutions and are associated with addresses in Canada or the U.S. If you are using a payment card, leave the apartment/suite number in the payment information section blank.
