Moderator
Jonathanlutes56
Acct is still suspended despite paying bill a week ago
@Jonathanlutes56 is the money sitting in Available Balance?  If yes, look for the active or reactive button to get it transferred.  AutoPay only works on the renewal date, every other day, you will need to force the payment to be accepted for renewal.
geopublic
@Jonathanlutes56  While you are waiting for the moderator to respond, you may try the lost/stolen phone trick:
To report your phone stolen. Login to your selfserve account. Choose Plans and Add-ons tab. Choose the Lost/Stolen Phone tab. Choose Suspend Service tab. Wait a few minutes. Report your phone found. Re-start you phone
Dunkman
@Jonathanlutes56
If you have any issues with account, you will need to contact moderator via private messaging.  It will take 1-2 days for response.
Send a private message to moderator through the following link :
You might want to try a few things prior to messaging moderator.
Might want to try two tricks that might re-activate/reset your plan:
1.  Report your phone lost/stolen in self service account.  Logout.  Wait few minutes.  Login.  Report your phone found.
2.  Manually add $1 into your balance.
These actions sometimes will reset your SIM/re-activate account.
https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/SOLUTION-My-plan-has-enough-f...
popping
Only moderator has access to your account.  Send a private message to moderator for help.
Moderator wait time is 2 - 3 days.
