Moderator_Team
Keimj
How long dose it take to get a response just wanting to port my wife’s number in from Koodo repaid
thanks
geopublic
thanks
@Keimj  Best to continue to use the Koodo prepaid sim until it stops working. Once that happens then the port is 100% complete and you can insert your PM sim in the phone and away you go. The reason I'm saying this is because the Koodo sim will probably stop working before you get a response from the moderator.
Keimj
Also I sent an email yesterday and Friday to the moderator team
GinYVR
@KeimjCould be up to 48 hours or more depending on the Moderators' workload. Unless there is a huge incentive to move from Koodo prepaid to Public Mobile.. at this point in time I won't recommend it.
