07-14-2026 03:17 PM
Why do I keep getting this message? I am trying to book an appointment, and it is not working. What is the problem?
07-14-2026 04:03 PM
I just rebooted my phone, and I clicked Reset network settings, and it worked. Off to make a couple of appointments.
Thank you kindly for your help
07-14-2026 03:21 PM
how much data you have? your mobile data turned on?
07-14-2026 03:20 PM
use this link to message Customer Support...then watch the Community in box for their response..
07-14-2026 03:19 PM
hi @Alex244ever
can you make phone calls? do you see the phone connected to PM network?
did you turn on Mobile data? and you don't have data limit set?
try Reboot your phone and click Reset network settings
