Mobile hot spot
04-26-2017 12:56 PM - edited 01-04-2022 01:43 PM
Im using a unlocked note 5.
I dunno why but my laptop doesnt want to work with my hot spot.
It (my laptop) can connect to the thing and it even says Im connecting to the Internet but its a liar cuz I cant.
So anyone knows whts the problem? Many thx!!!
Joining Public
04-26-2017 04:20 PM
04-26-2017 03:11 PM
not really (never though of hot spot before)
04-26-2017 03:09 PM - edited 04-26-2017 03:10 PM
Desktop doesnt work too and its already <<dun>>
04-26-2017 03:06 PM
have you ever tried it with a different provider?
04-26-2017 02:44 PM
Is it just your laptop? Or do you have another wifi device that you can try to connect, to see if it's an issue with the phone or the laptop?
My initial instinct would be that it's maybe an APN issue. From previous posts on this issue, adding "dun" to the apn type seems to have helped.
04-26-2017 02:33 PM
Also my phone have more choices for security
04-26-2017 02:06 PM - edited 04-26-2017 02:07 PM
I only have two options (open or WPA2 PSK) and none of them work.
04-26-2017 01:34 PM - edited 04-26-2017 02:03 PM
Select a different secuity when you create hotspot they do give you different security option try different one
Here's a screen shot
Click on side menu ans select configure hot spot and change security option try all one by one hopefully that will resolve your issue
Thanks
