11-14-2019 12:08 PM - edited 01-05-2022 07:59 AM
I recently started a public mobile connection. My plan shows 250mb 3G data. But my LG G5 does not show data connections though the text and calls are OK.
Is there a setting I need to change. I earlier used LTE data on FIDO with the phone.
Thanks
11-14-2019 12:38 PM
@Piroy If a network reset doesn't fix it then you will need to do a factory reset to get data going. Don't forget to backup your data.
11-14-2019 12:21 PM - edited 11-14-2019 12:23 PM
@Piroy wrote:I recently started a public mobile connection. My plan shows 250mb 3G data. But my LG G5 does not show data connections though the text and calls are OK.
Thanks
For LG G5, you need to do a network reset on your phone before your data working again after changing provider. After reset, restart your phone to have your APN setup automatically for PM service.
- Enable mobile data
- Network reset
- Restart phone
11-14-2019 12:10 PM
Make sure you setup the PM APN settings.
