Mobile Data / Hotspot
e55meg
My phone data still does not work but it Does provide data on Hotspot to my tablet!?
I made changes to APN settings I found here in posts.
Something is still not right?
@e55meg   so, the mobile data still ONLY work as a hotspot but the phone itself cannot use the data?
You might want to check the Permission of each app, see if the app is disabled for Mobile data.  And try different app
and I guess you should turn off the Mobile hotspot first and focus on making the phone works with data first
btw, what phone is that?
e55meg
Screenshot_20230404-183819619.pngScreenshot_20230404-183841405.pngScreenshot_20230404-183913266.pngScreenshot_20230404-183819619.pngScreenshot_20230404-183841405.pngScreenshot_20230404-183913266.png
Andyrob26
Have you tried restarting your phone?  I know basic but it has worked when a similar thing happened to me in the past.
 @e55meg try different app, maybe that specific one was not enable for data?
dust2dust
Give us images of your apn settings and maybe we'll spot something.
