Mobile Data Connection keeps dropping
PDub
In the past few days I've had problems accessing mobile data and that's never been a problem before. Is it possible this is a PM issue? Are there any steps I should take to make sure this isn't a provider issue? I have already reset network settings. This is an iPhone 6s iOS 13.7.
Thanks.
RosieR
Thanks.
Hi @PDub it seems that Apple’s iOS 13.7 could have a tremendous impact on your iPhone 6s or iPhone 6s Plus’ performance.  Check out this link https://www.gottabemobile.com/8-things-to-know-about-the-iphone-6s-ios-13-update/
Also check out iOS 13.7 Problems here https://www.gottabemobile.com/ios-13-problems-5-things-you-need-to-know/  "As of right now, it’s unclear if the iOS 13.7 update fixes the issue. In the meantime, it looks like turning off Background App Refresh in Settings could help."
popping
@PDub
Check your iPhone for update.
If yes, update it or connect your iPhone to a computer running iTune to update and download the PM specific carrier file to configure your APN.
gpixel
@PDub what plan are you currently on? can you login to your self serve account and check to see if you have any data remaining. if you don't see any data fields under "overview", you've most likely used it all up
Helpershelper
@PDub
I can understand your frustration with this. The network looks good from here, no outages. You can see real time outage information here:
https://www.telus.com/en/on/outages
If you’re in an area with poor reception you can try Cloudflare WARP and see if you notice improvements:
https://play.google.com/store/apps/details?id=com.cloudflare.onedotonedotonedotone
https://apps.apple.com/us/app/1-1-1-1-faster-internet/id1423538627
https://blog.cloudflare.com/1111-warp-better-vpn/
I would also make sure your phone’s OS is up to date.
popping
Thanks.
Use your PM SIM on another known working phone.  This will determine whether the issue is your phone or PM account setup.
If your PM SIM card works in another phone, it is your phone problem.
If you PM SIM card does not work with another phone, it is PM account problem.
