Misspelled email
Ascwin
Moderator_Team
Walmart misspelled my email, how can I change my email?
1 REPLY 1
will13am
@Ascwin, you will need to do this in two steps.  Immediately you can log-in to the self serve using the misspelled email and correct it in the self serve.  Separately, contact the moderator team and have them change it on their end so that things like password reset emails will be sent to the right address.  The moderator team can be reached via private message using this link.  Refer to the following knowledge base link for additional information on contacting the moderator team.
