Missing rewards
Sharon_Ferguson
I joined public last November and just learned the person that  refered me hasnt received  his reward how do i fix this
Yummy
Ask your friend if he sees last 4 digits of your phone number.
That would mean you applied his referral code correctly and everything is in order. Reward might appear on next billing cycle if not immediately..
HALIMACS
@Sharon_Ferguson
Indeed, the person seeking the reward needs to contact public mobile. However, given we’re talking almost a year since the referral was made, it’s quite possible, they may not apply it, or maybe the code was entered incorrectly on the activation, and someone else is benefitting from the referral.
Another possibility is that the other person switched to the new public points program in which case they would no longer be receiving the referral reward every cycle.
HI @Sharon_Ferguson  did you get your $10 ?
Yes, you will have to help the one who referred you to get the reward, please open ticket with PM Support:
at : https://publicmobile.ca/chatbot.
Start by Typing: My rewards are missing,
Select "Public Points"
click on "Refer A friend",
then click on "Yes, I'm the referred customer',
finally click "Click here to submit a ticket" .
will13am
@Sharon_Ferguson , what rewards are you missing?  Anyway, you would need to use the chatbot link at the bottom of the webpage to initiate a support ticket.  A CSA will restore any missing rewards.
