07-24-2019 01:17 PM - edited 01-05-2022 06:04 AM
07-24-2019 01:27 PM
If you click in the upper right hand corner "My account" and then on the left hand side of the page in the middle click "my plan" and click "plan details" does it accurately reflect 1.5 gb plus 3 gb promotion? If it does not, under "my plan", you can click "change plan" to view all the plan options available to you if you wish to change plans. You then have the option below once a new plan is selected to "change plan now" or "change plan on renewal date." Hope this helps!
07-24-2019 01:19 PM
@liny wrote:
Hi,
I ported my number from bell and my plan is 1.5gb +3gb as a promotion. But it says now i have only 1.5gb . Last month also I did contacted the moderator team to fix it. Can someone please help me to update my plan.
Thanks
liny
Just do exactly what you did last month. It should be recurring but I guess it needs manual intervention.
@Moderator_Team < Click this.
07-24-2019 01:19 PM
@liny wrote:
Hi,
Thanks
liny
Only moderators can fix account issues. Please send Moderator_Team another message.
