Missing Text Messages
06-10-2018 11:22 PM - edited 01-04-2022 06:09 PM
It has occurred multiple times now where someone would text me and I would not receive it. The sender would not receive any undelivered text errors. This has happened to people who from various carriers sending me messages and it occurs multiple times in a day. This has been very frustrating to deal with.
Phones
06-11-2018 01:33 PM
Let us know if its solved or not. or need more helps.
06-11-2018 01:54 AM
@Crisie_85 knowing what phone you are using (brand, model, and verison of iOS or Android if possible) would help us troubleshoot better as well.
06-11-2018 01:39 AM
Roaming might be one thing, it used to have that bug before.
SEcond is did you change your setting, when did you last time able to send/receive message without issue?
Perhaps try it on another phone to figure out if phone related issue.
06-11-2018 01:26 AM
@Crisie_85 do you happen to travel to the USA and use a US Roaming Texting add-on approx 10 days before the problem tends to occur?
06-10-2018 11:34 PM
@Crisie_85 are you using imessage?
06-10-2018 11:32 PM
@Crisie_85, if this is happening randomly, and some messages are getting through then it is likely a problem on Public Mobile side. Could it be something having to do with the people sending the messages? Are they all on iPhones (for example)? Are you on an iPhone? Was it working previously, and just started happening? If you can provide more specifics, perhaps someone might have ideas. If it is purely random, send a private message to the moderator team and explain the situation.
Click here to send the moderator team a private message. Their hours are: Mon-Fri 9AM-9PM(EST) & Sat/Sun 9AM-7:30PM(EST)
You can find information regarding the moderator team by following this link.
![](/skins/images/C206B3E09108DC4A8294A110EB9CCA46/responsive_peak/images/icon_anonymous_message.png)
