Missed incoming calls do not show? (Android)
Jaujo
Hi all, I switched to PM 2 months ago, and I seem to notice the incoming calls I miss do not show in my history or as notifications.
My phone is always on silent or vibration mode, so I do miss calls pretty often, but I used to be abke to see who called me and when on my pock screen. Is that normal and can I make the missed incoming calls show up again?
I have unlimited calls and text in Canada and am on Android.
Thank you
1 ACCEPTED SOLUTION
Accepted Solutions
Timer
@Jaujo
tried rebooting device.mabye need update your ios.
tried use browser from computer, clear cache and cookies and use one page inPrivate mode,
To Login Page
and check the number at your history calls.
Timer
@Jaujo
To Login Page
@Jaujo
For these calls in question, does your phone actually "ring" (without sound)?  I ask because if there's a network issue causing calls to go directly to voicemail, your phone wouldn't be aware of that.
Jaujo
Restarting my device seems to have worked, at least for the one phone call I tried. It was too easy a fix to think about it. Thanks
akkerala
Check your call forwarding settings and make sure it's turned off. Then restart the device.
