Message unauthorized
Ericsparrow56
Anyone having this issue when trying to log into their self serve account?  No matter what I try, it still shows up.  I've tried on 3 different phones, a laptop and 2 other people's phones...all the same outcome.  I've tried to submit a ticket AND resetting my password, and it says there was a issue.  My plan is active too. Everything is working the way it should.
12 REPLIES 12
ValeryD1
I dealt with the problem by changing the passport and clearing the cache.
The first is to clear the cache, data of the apps on the phone and the cache computer (chrome)
Second, when entering your account, select the option - I forgot my passport and go through the procedure for changing the passport.
parkerremy2
Ok, great. So if it were account related how would it make any difference if they had tried to sign in via another device or laptop/computer?
HI @parkerremy2   yeah, that's great.  OP confirmed it could be account related and not just cache.
@Ericsparrow56 wrote:
Ok..so it's not just my account.  Funny thing is, my girlfriend and daughter can sign into theirs no problems.
HI @Ericsparrow56   they can login on the device you tried?  then yes, it could be problem on the backend, open ticket with CS Agent
JL9
Yeah a bunch of different errors and screens come up it seems, even before the new overhaul, bit of a pain but I guess it just comes with the territory
Ericsparrow56
parkerremy2
OP clearly stated that they had tried multiple different devices and a laptop
parkerremy2
YES it's driving me insane. They need to figure this out and fix it
Hi @Ericsparrow56
um.. it works for me.
Try another device (computer or phones)  if possible.
Maybe a ticket with PM CS Agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
Ericsparrow56
I've tried all that. Still nothing
Timer
@Ericsparrow56
open from computer browser and use one page inPrivate mode,
HI @Ericsparrow56
Yes, I got it too sometimes,  I used another browser and can get back in
You can also clear cache and restart browser, or use Incognito mode.
