Showing results forĀ
Search instead forĀ
Did you mean:Ā
Making the switch 🄶
DDM69
I was about to switch my plan from $40 plan at 3G speed to $40 4G speed but…I do not want to switch to the new points system.
Why does the new plan state ā€œ3 times the points backā€ if I’m not agreeing to change to the new point system?
Now I have cold feet 🄶
ā€ƒ
It will switch on my renewal date. Nov 16
Thanks
hairbag1
@DDM69...
It's been noted that the 4G speeds don't kick in right away...give it a coupla days.
Let us know if you experience noticeable improvement.
RossN
@DDM69 your welcome
DDM69
@RossN Thank you 😊
RossN
@DDM69 hi don't worry that line is in there for new customers that is not going to happen to you  unless you go into your account and change to the points system , you can keep your old rewards system, enjoy your new plan šŸ˜Š
