04-14-2015 12:58 PM - edited 01-04-2022 01:21 PM
Hi
I have BlackBerry Bold, APN and DATA settings are enable but i am not able to send and received picture messages just to make sure that picture message is include in my plan. Any advice will be help ful.
Thanks
12-01-2016 12:40 PM
Picture messaging on BlackBerry smartphones requires the BlackBerry 10 operating system or newer.
11-30-2016 05:09 PM
@Cyber, how about blackberry OS 6.0?
I filled out most of the information but it still does not work.
What should I do?
Anyone? can help?
04-15-2015 12:22 PM
There you are ^
Amasa.
04-14-2015 07:16 PM
Hi @ASYED
From section 3 of Public Mobile's Plans page;
Blackberry Bold is pre-BB10 software so it will not work.
04-14-2015 05:07 PM
For Apple it is different.
Amasa.
04-14-2015 01:31 PM
Yes, Android, BB, ans Apple each have their own Acess Point Name ( APN settings) which controls the access to the gateway Data services each carrier has as part of their services. Perhaps Public Mobile should consider having a APN settings guide for each brand, Android, BB, Apple, so that ppl have correct info on this. I believe this is essential, for the DIYS day of age, as part of the tools of the trade for the average handsettyman and handsettywoman and of course handsettychild
04-14-2015 01:14 PM
For MMS and DATA (internet), you need to have the correct APN in your phone.
Picture messaging on BlackBerry smartphones requires the BlackBerry 10 operating system.
Step-by-step APN configuration :
Step 1
Blackberry
OS 7 and lower (BB curve, Bold, Torch, storm) - All > Options > Device > Advanced System Settings > TCP IP
OS 10 - Settings > Network and Connections > Mobile Network > Tap the settings icon (dented wheel)
Step 2
You will need to input the following information :
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: default,supl,mms,dun
Step 3
Select Save/Done. Select Public Mobile to connect to the Public Mobile network.
If I answered your question, please accept my post, as the solution.
