11-25-2016 01:39 PM - edited 01-05-2022 12:57 AM
11-25-2016 05:54 PM
11-25-2016 02:21 PM
Try your Telus SIM. If it's working just keep using it until it stops. Do not cancel your Telus account.
11-25-2016 01:58 PM
You need to contact moderator by private message or tagging them on the post. Even you post in a forum, you will still need to send a message eventually due to your private information.
See the link below to know how.
11-25-2016 01:43 PM
Have you message mod yet?
If not, please message them ASAP.
You have two channels to report the issue
Webpage> Get help> contact us
and/or
Private message mod from here
I would recommend you to do both. Please take note that at the moment, there's probably going to be a week long wait for fixing this issue. You can also try message public mobile through facebook.I had better luck with faster response there.
Refer to this link regarding how to message mod
