04-07-2022
10:41 AM
04-07-2022
05:48 PM
computergeek541
Hi, the mms does not load in my number. How can I fix this?
04-07-2022 04:01 PM
it worked, thank you.
04-07-2022 04:01 PM
It worked. thank you.
04-07-2022 03:17 PM
Add ,mms after default in APN type. No space before or after the comma.
04-07-2022 03:15 PM - edited 04-07-2022 03:17 PM
@Dristal is the MMS port showing 80 there after the network reset?
also, check this line:
APN type: default,mms,agps,supl,fota,hipri,dun
04-07-2022 03:13 PM
I reset my network and followed the steps but it's not working
04-07-2022 02:57 PM
@Dristal Try first reboot the phone, then a network reset again and then go back and make sure the APN settings are all correct
(please note with network reset, your saved Wifi will be gone, too. You will have to re-join all Wifi networks again)
04-07-2022 02:51 PM
I did everything you said but the MMS still does not load. The data is on and the internet works.
04-07-2022 02:40 PM
@Dristal You missed the MMS port, set it to 80
Ensure the following fields match:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMSC: http://aliasrediect.net/proxy/mb/mmsc
MMS port: 80
MCC: 302
MNC: 220
04-07-2022 01:52 PM
yes
04-07-2022 01:25 PM
oppo F11 pro
04-07-2022 01:01 PM
@Dristal wrote:I have my data on but it is still not working
Can you send/receive SMS? Everything else works (calls, Internet)?
04-07-2022 12:55 PM
@Dristal What brand and model is your phone?
04-07-2022 12:32 PM
Can you open web pages? Can you give images of your APN settings here.
04-07-2022 12:32 PM
I checked my APN setting and it has every detail that it needs but its still not working
04-07-2022 12:27 PM
04-07-2022 12:27 PM
04-07-2022 12:27 PM
android
04-07-2022 11:03 AM
You have to have DATA on on your phone to send/receive MMS. It will not use your data allowance, though.
04-07-2022 10:58 AM
Data being disabled is usually the reason for this, sometimes its gets switched off accidentally
04-07-2022 10:43 AM
@Dristal MMS requires Mobile Data to be enabled. Is your Mobile enabled?
If enabled and still not works, check the APN settings.
(what kind of phone you have? Android? iOS?)
