01-04-2022 10:12 PM
Help please!
If I send an MMS to someone that doesnt have data, will they still receive the text but not be able to download it? Or will they not get anything and have no idea I texted them till data is on?
Thank you!
01-02-2023 12:47 AM
They should recieve text...then their data account (APN) has to be on in order to recieve MMS
They can adjust data account just for APN if their phone a bit more modern...my 2011 doesn't have APN type options
Basically Ecosia (do search... P.s. that's my search engine I use ) with keywords MMS APN here in support
01-04-2022 10:55 PM
Thank you to everyone who took the time to respond, I appreciate it.
01-04-2022 10:52 PM
Thank you
01-04-2022 10:36 PM
@darlicious wrote:When I was with telus with a data block on my flip phone I was given a link and/or the website address and a reference number to view the MMS sent to me in an SMS text.
@darlicious - neat.
When I set my phone up for my Dad with his provider (not PM), there was no way in h#$* that he wanted any surprise charges (which happened in the past on him) and didn't want to get mixed up in needing to find that "off" button to ensure data was disabled.
That method you were given would have been WAY too complicated for my lovable, yet "Make IT as Easy as Possible" Dad.
Oh, fun times! 😂
01-04-2022 10:30 PM
01-04-2022 10:27 PM
@1kmmoore - only the recipient can answer that.
Some cell phone customers get the Data turned off from the Providers end so they cannot even have the ability to 'accidently' use it.
And some users NEVER turn on their data. So, the recipient may just get a constant reminder ( a bing now and then) to enable data, or it will just sit in their Messages as unopened.
You would be able to send them a follow up text (without a picture, non-MMS) and ask them if they were able to open it; they would see the follow up SMS just fine.
01-04-2022 10:19 PM
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet Wi-Fi is on is not going through the Picture or a video messaging,
you have to do this to going through you will need to turn your data on to send a Picture or a video messaging in world-wide,
make sure your Data is on.
01-04-2022 10:17 PM - edited 01-04-2022 10:18 PM
MMS does not require data. Just make sure their cellular data is on and their APN settings are configured correctly on their phone.
01-04-2022 10:17 PM - edited 01-05-2022 01:15 AM
Depending on the provider they may still be able to view the MMS as long as they have mobile data turned on like here at public mobile. Otherwise they will recieve an SMS telling them they have a MMS and will be given a link to go to a site to view their MMS.
