07-31-2020 11:55 AM - edited 01-05-2022 12:20 PM
I am unable to send pictures via MMS when I do not have my data turned on...if I turn on my data will sending pics via MMS use my data as I have the $15 plan which has unlimited text and picture sending?
Phones
07-31-2020 11:58 AM - edited 07-31-2020 12:10 PM
@ematias Hello unfortunately you need to turn on your data it does not take away from your data but your data needs to be turned on
07-31-2020 11:58 AM
Thank you!!
07-31-2020 11:57 AM - edited 07-31-2020 11:58 AM
@ematias wrote:I am unable to send pictures via MMS when I do not have my data turned on...if I turn on my data will sending pics via MMS use my data as I have the $15 plan which has unlimited text and picture sending?
You need the data turned ON to send the picture message...but it won't take data from your account.
