MMS won’t come through
hodged4
Hi All, I recently changed over to a dumbphone (TCL Flip) and I can’t seem to get MMS to receive or send. I de-registered from RCS and I double checked the APN settings. This is what they are set at and still nothing. Hope someone knows why.
APN: sb.mb.com
MMS proxy: mmscproxy.mobility.ca
Mms port: 8799
MCc: 302
MNC: 220
APN type: default,ia,mms,supl,fota,hipri
APN protocol: IPv4/IPv6
APN Roaming Protocol: IPv4/IPv6
Bearer: LTE
MVNO value: 4D4F
MVNO Type: gid
1 REPLY 1
@hodged4
Telus (PM) has retired some legacy servers and old phones from 2017 before will be affected
and check if you have these APN settings
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
