10-16-2023 12:28 AM
Hi, getting really frustrated, can't get MMS to work. It's a new unlocked Umidigi G3Max phone and here are the APN settings:
name: sp.mb.com MMSC: http://aliasredirect.net/proxy/mc/mmsc MMS proxy: mmscproxy.mobility.ca
MMS port: 8799 MCC: 302 MNC: 220 APN type: default, mms,supl,fota,hiprl,dun APN protocol: IPv4
APN roaming protocol: IPv4 MVNO type GID MVNO value:4D4F
Any help would be greatly appreciated,
Jacques
10-17-2023 10:10 PM
Thanks, it works now
10-16-2023 12:53 AM
Yes, the MMSC is wrong.
10-16-2023 12:49 AM
Confirm settings below. Is your data on? Have you tried rebooting, resetting network setting?
10-16-2023 12:48 AM
@Marjac Make sure your cellular data is turned on. Try removing "dun" from the APN Type config, leave it to "default, mms,supl,fota,hiprl".
