MMS not work iPhone 8 plus
ekossev
Hi
I have tried everything to get MMS to work.  It simply won't work for me. Is therea moderator that can assist?
I have an iPhone 8 plus iOS 12.4
Thanks.
ekossev
The network reset from settings fixed it this time around. I did a restart and it's it'sing perfectly now. Thank you.
@ekossevCan you access data just fine ie via Safari? If so, try turning off the iMessage check box, then turn it on again. Does iMessage / MMS work under wifi?
ekossev
I have tried this already. Not working either.
ekossev
Yes I have. Still not working
Triguy
Did you enable data even though MMS does not use your data ?
Moderator can be reached at
GinYVR
@ekossevTry reset the Network Settings under Settings -> General -> Reset. Also have you enable MMS fallback under Messages? Even if you have no data you need to enable it for you to be able to use MMS.
Enable SMS and MMS in iOS MessagesEnable SMS and MMS in iOS Messages
