Thursday
I just installed the PM app and I see that it installed Mobile Klink app.
How do I remove it. It auto installed and doesn't have an uninstall feature.
Thursday
I'm assuming you are using an Android phone? If so it seems like removing it can be a bit complex.
I found a Reddit post that states: If you can't uninstall it from the apps screen in the settings, then you can still uninstall it with ADB by connecting your phone to your computer, and using something like AdbAppControl to uninstall whatever you need to. Just be careful not to remove system apps, which Mobile Klinik is obviously not.
You may wish to leave it alone if you aren't comfortable doing that.
Thursday
@StuGattz if you go to the playstore you will see all your installed apps. Click the app on question. There should be a button to uninstall.
Thursday
HI @StuGattz
you are using PM service now, right? the MK app likely came down as part of the activation. All carriers will push down some related app
just go to the Settings->App and look for the MK app, see if there is a uninstall option. If not, you should at least have option to Disable it
