11-23-2023 12:11 AM
I still have the old loyalty pay discounts on my current plan as well as the $2 auto pay discount. If I change to one of the current Black Friday plans, will I lose these discounts?
11-23-2023 08:21 AM
11-23-2023 04:48 AM
11-23-2023 03:34 AM
11-23-2023 12:32 AM - edited 11-23-2023 12:34 AM
Hi @Freedom_strike2 ,
You rewards are associated with your account and not your choice of plan. You can pretty much change plans whenever you'd like and you will always maintain your rewards so long as you keep your account 🙂
Just make sure that you do not opt for the new points system. That would replace your old legacy rewards program (which is a disadvantage).
Hope that helps reassure you! Take care!
11-23-2023 12:24 AM
No.
