Lost of all of my rewards when upgrading plan
Botengu
I had referred two friends to public mobile and had loyalty rewards (3$/per month). I have lost all of it when I upgraded to the 34$/month 20G plan.
How can I get those back?
Thanks
@Botengu - give it a day or so, then check your payment history. You should see your rewards applied.
@Botengu
Just as long as you didn’t voluntarily switch to the Points Rewards system. You will be fine but once you switch unfortunately you can’t switch back.
Hollister
@Botengu
Did you do an immediate plan change? If you did you do not get any rewards applied to the plan change.
Changing plans doesn't cause loss of rewards.  If an immediately plan change was performed, rewards will be issued in a day or two.
