6 hours ago
I need to downgrade to the $19 per month plan. When I log in and ask to change my subscription, it’s not there? Help!!
5 hours ago - last edited 5 hours ago
If you want to keep your number but just don’t need all that data etc consider Freedom Mobile - they do offer a $5 basic plan with unlimited texts but only 120 voice and also only 100 mb of 5G data . Hope you get this before a zealous oracle removes this post . Good luck. .
I got this plan for my grandmother and she’s quite happy with it . My wife is now also considering to port to freedom because she mostly uses WIFI at home and at relatives homes.
6 hours ago
hi @Cat50 if you like PM, you can port out and port back in
and what is the cheapest plan you see there? $30?
I would also check with PM agent again, maybe submit a ticket and ask
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
6 hours ago
I was paying $15 per month and upgraded it for the summer to have a hotspot at my trailer. Now I wanted to downgrade it for the winter while I’m out of the country. I guess looking for a new provider is my only solution.
6 hours ago
hi @Cat50
plan change not as flexible as before. you can only change to plans available on your account. And generally it is harder to downgrade your plans, less plan with lower values will be available
6 hours ago
@Cat50 That’s because the $19 plan is just for new activations , public mobile has made it harder to downgrade plans . We can only change to what’s available to us to change to in our accounts
