Long Distance - Cannot call Spain
Bandolin1
I have 400 minutes of Intl minutes (including US & Canada) but when I try to call Spain, I get a message from Public Mobile that the number cannot be completed as dialed (+34 911 230 000)
pmbc
@Bandolin1  Did you buy the international addon for the international minutes?  If so, you're right Spain is listed in the supported countries.  Just want to make sure you didn't buy one of the international mins addons.
I would contact CS_agent to see why you're getting the message that it cannot complete as dialed.  You can reach CSA directly here,
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437.
Bandolin1
Brilliant. Thank you.
Hollister
@Bandolin1
Try putting 011 in front.
