Long Distance Calls
1623
  • Hello, looking forward for the opportunity to make long distance calls
2 REPLIES 2
slusagm
Where you want to calls and what plan you have?
PM has different long-distance add-on you can buy depends on where you want to call.  Check your My Account, Shop Add-on page
TheSterlinger
That's a very broad statement.
Which plan do you have? Have you tried to make a call and it's not working?
