12-19-2020 01:40 PM - edited 01-05-2022 04:33 PM
Hello, my acct got logout. Cannot reset pswd, security question failed.
12-19-2020 04:32 PM
@Spudster No worries. Enjoy the holiday season and stay safe!
12-19-2020 04:29 PM
Yes, i see the security question now - didn't even recall having had created one.
Tks
12-19-2020 02:48 PM
It does this time when I submitted email to reset password. I dont rmb setup security questions either
12-19-2020 01:55 PM - edited 12-19-2020 01:56 PM
If you don't remember your password to login. You can click "Forgot password" that is where you would be asked to enter your security question.
If you like to change your security question and have access to your account.
12-19-2020 01:55 PM
@Spudster wrote:Does PM use security questions on their login? Don't remember doing so...
No, not on login, but it will be used on the Forgot my password link.
12-19-2020 01:54 PM
Yes, Certainly. There is a security question that you must set during the activation process with Public Mobile.
12-19-2020 01:52 PM - edited 12-19-2020 01:58 PM
If you've forgotten your Self Serve password, remember that it must contain a minimum of 6 characters, including at least one digit. No spaces are allowed.
12-19-2020 01:47 PM
12-19-2020 01:42 PM - edited 12-19-2020 01:42 PM
Contact moderator's.
Or private message at below link.
