Login problems
Ed_A
I receive my EverSafe confirmation code, but there is no “Confirm” button on the screen, so I can’t access my account.
2 REPLIES 2
@Ed_A are you using the App or browse on the phone?  Try both.  And try scroll down, there usually a big banner at the bottome covering that, but scroll down the top part helps to see the Confirm button
Worst case, try using browser on a computer
@Ed_A  No worries get support to help
send  a  private message   To CS_Agent
